Wall mounted or stands?
Discussion in 'Home Cinema Speakers' started by Captain Ted, Jun 24, 2005.
  1. Captain Ted
    Captain Ted
    Jun 12, 2005
    511
    +15
    I have a square room in which I am dedicating to a cinema room.
    I have plenty of room to wall mount my speakers or use stands.
    Which sounds best (before I buy the stands).
    Thanks,
    Ted.
  2. u32t5645
    u32t5645
    It's likely your speakers will sound the same either way. Aesthetics should dictate. My personal preference is for wall-mounted with the speaker wires buried in the wall. Also, wall mounting allows you to get the speakers up a wee bit higher, if that becomes necessary.
  3. Artie Fufkin
    Artie Fufkin
    Aug 11, 2004
    1,600
    Aberdeenshire
    +182
    You must already have your speakers - bookshelf types, I assume. If so, as u32 says, it's a matter of aesthetics although some may argue that stand mounted will improve bass.
  4. Captain Ted
    Captain Ted
    Jun 12, 2005
    511
    +15
    They are the small satellite ones.
    Suppose the kids can't knock them off the walls either.
