Wall mounted KEF eggs??
Discussion in 'Home Cinema Speakers' started by NAU, Jul 10, 2004.
  1. NAU
    NAU
    Hi folks,
    this is probably a dumb question, but I'll ask anyway before I spend not inconsiderable lumps of cash! All the pictures I've seen of KEF eggs show them either on a shelf or on a stand. And I can't really see how the stand on the bottom of the egg allows it to be mounted on a wall.
    Can someone in the know please confirm to me that these can indeed be wall mounted as I want to have one either side of my TV and one above, all screwed to the wall.
    Thanks.
  2. 337GUS
    337GUS
    Nov 1, 2000
    753
    NE Scotland
    +38
    yes they can - there are 2 screw holes in the base.
    Gus
  3. inzaman
    inzaman
    Dec 16, 2002
    7,964
    Derby
    +1,029
    Will also confirm the above as i used to own a set of eggs, they can definitely be wall mounted by using the current bases.
  4. NAU
    NAU
    Thanks :thumbsup:
