Wall mounted centre
Discussion in 'Home Cinema Speakers' started by le hutch, Mar 23, 2001.
  1. le hutch
    le hutch
    I've just purchased a Monitor Audio Siver 12i centre speaker (mmmm) and as I hate the look of it on top of my telly, I was looking for a suitable wall bracket for it.
    Does anyone have any comments or suggestions?
    Thanx in advance...
  2. General Skanky
    General Skanky
    Jul 28, 2000
    4,247
    71
    +43
    Can't you make one from wood? I ask assuming you can 'bodge it and scarper' DIY style.
    Personally, a well made DIY platform with DIY isolation employed, ie, small cross head screws under each speaker foot, will give as good results as a bought unit costing lots more.
    Douch!!......Wot's da madder, da CIA got you pushing too many penzils?
    Work: www.hughes-tv.co.uk
  3. RobsterD
    RobsterD
    Dec 11, 2000
    891
    Southampton
    +12
    Your best bet is a tv wall mounting bracket,I'm using one from the Argos catalogue it's for a 21" TV and it holds my B&W CDMC perfectly,I've even got a tilt option !!
