Wall mountable Bi-Poles for centre back channels?
Discussion in 'Home Cinema Speakers' started by steve 111, Nov 17, 2004.
  1. steve 111
    steve 111
    Jan 5, 2003
    551
    Newport, Gwent
    Going to upgrade from 5.1 to 7.1. Currently have MA BFXs as my surrounds and now need a pair of wall mountable bi-poles to match them. £180 for another set of BFXs seems a bit of an overkill for the 6th and 7th channel so looking for something around £100 for the pair.
    Anyone any recommendations?
  2. mike_cummi
    mike_cummi
    i'd just stick with monopoles at the back mate, another set of bipoles might just end up confusing things at the back.
  3. steve 111
    steve 111
    Jan 5, 2003
    551
    Newport, Gwent
    I know what your saying but I want to wall mount and most monopoles need to be mounted a few feet from the back wall which I don't want to do due to WAF.
  4. mike_cummi
    mike_cummi
    most compact bookshelf models should be fine on wall brackets, as long as they are not overly heavy or rear ported shouldn't be a problem.
  5. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
  6. Export Strength
    Export Strength
    Nov 1, 2004
    44
    +4
    You definately want monopoles as rears - i would stump up and get a pair of Bronze 1's and be done with it. Use a solid wood shelf rather than a bracket (it looks better) and don't worry about their being close to a wall, thats really only a problem if your using them as front stereo speakers. The tonal match between them and the BFX's will be perfect.
  7. steve 111
    steve 111
    Jan 5, 2003
    551
    Newport, Gwent
    Export,
    Why should I go 'definately' go for monopoles rather than bi/di-poles for the centre back channels?
  8. Export Strength
    Export Strength
    Nov 1, 2004
    44
    +4
    Steve,
    Mike had the answer. Another pair of di/bi poles would confuse the audio presentation. The simple answer however is that the sixth channel - that you're splitting in to two channels - is a mono signal and, for technical reasons I'm unable to explain in simple terms, is not ideal for di/bi poles.
    In a 5.1 set-up di/bi poles are fine as rears or sides but within a 7.1 the best - and correct - arrangement is to use monoploes for front LCR and back LR with di poles on the sides.
