Wall Mount?
Discussion in 'Home Cinema Buying & Building' started by DeeDee, Apr 29, 2005.
  1. DeeDee
    DeeDee
    Currently looking for a wall mount for an LCD 26" I've just bought. (17kgs).
    What kind of mount do I need?
    There are 6 wall mount holes on the back, all 100mm apart from each other. Can I just get a normal VESA mount and only use 4 of the 6 holes on the back? I can't seem to find any mounts with all 6 holes!
    Thanks.
  2. SeanT
    SeanT
    Jan 28, 2005
    6,126
    Coventry
    +371
    i think you will find that there are six holes so you can choose from two levels to mount it at (eg. on a fixed height stand)
    Four VESA sized machine screw holes as you say will hold screens upto 50kg+, so I wouldn't worry mate!!!!
  3. DeeDee
    DeeDee
    Thanks for the reply.
    So basically, I just need to find a normal VESA mount (I've found a nice one with a tilt) and it will be fine? (Well, 100mm one) (then just use 4 of the 6.. )
