wall mount
Discussion in 'Home Cinema Buying & Building' started by cruncher75, Nov 13, 2003.
  1. cruncher75
    cruncher75
    Nov 1, 2003
    1,421
    southampton
    +117
    how easy is it to put the bracket up and how big are the bolts or screws that come with it or do i need to buy them and what holds the into the wall must be some sort of wall plug
  2. nealgs
    nealgs
  3. embees
    embees
