Hi experts
Just purchased the Toshiba 42x3030 and need to have the set mounted via a bracket that would allow the set to be pulled out from the wall and twisted etc.
As this is a big screen im terrified at the prospect of it falling from the wall within an hour of it being mounted..
Problem is, I have no other option due to the position in the room and to allow viewing from as many angles as possible.
So heres where I need your help...
1. My brother has mounted his tv via a bracket that sits flush with his wall and doesnt move, he reckons he can do mine....... Should I accept his generous offer or get a pro in to do it for me?
2. The wall its to be put on is an outside wall on a relatively newbuild home (13 years) and when I tap the wall I can hear hollow sections and then what sounds like brick... Could this type of wall take the wait of a 42" tv on a swingout mount?
3. Can anyone recommend a suitable bracket, while I wouldnt want to go to overboard price wise id rarther be safe and skint than loaded and on the search for a builder to replace my wall after the tv pulls half of it away..lol
Hope theres someone out there that can offer a bit of advice cause this sites been a godsend...
