MorganUK
Hello
I have got the above Plasma TV, which can be noted here...
50" FHD Ready Plasma TV PS50A558 - plasma TV - television | SAMSUNG
... I would like to wall mount it onto an internal brick wall. Whilst I am not bothered about the ability to swivel the TV the full 15 degree up/down tilt function would be useful.
Could anyone please advise which mount would be suitable for the above TV without it costing too much, but being perfectly safe and adequate for the job.
I have noted that the wall mount kits come with the screws that are needed but does that also include the screws to fit the mount to the TV..? Or do the ones that are fitted in the rear of the TV ok to use with any of the mounts sold..?
Also I did get four grey coloured "spacers" that I assume (they are about a centimetre thick) are actual spacers that could be used with a mount if needed, is that correct..?
Last point are the ones that are sold on ebay, which can be quite cheap, really that bad..?
Thanks for any help
Thanks for any help
