Wall mount on plasterboard AGAIN! but metal structure!?
Discussion in 'Home Cinema Building DIY' started by tim k, Dec 14, 2004.
  1. tim k
    tim k
    Awaiting delivery of plasma and mount from av sales this thu, need to mount onto my wall, its about 1 & 1/2 inch thick then hits steel structure. How can i mount!!??
  2. RemotecUK
    RemotecUK
    Mar 18, 2004
    54
    Birmingham
    Can you give us any more information..
    - What is 1.5 inches thick?
    - What is the steel structure behind the wall?
    - Do you have any photo's that we can look at?
    - Have you considered any other types of mounting brackets?
    - Is this the only place it can be mounted?
    etc.
  3. Walter mitty
    Walter mitty
    Aug 1, 2001
    232
    19
    Shropshire
    Have you considered a drill bit that will go throught the steel then use raw plugs as usual?
