Wall mount help
WalkInMyShoes
I need help locating studs in the wall, I have no clue on DIY but im wanting to learn, The wall feels like plaster board so I know for a fact it need support to hold a 32". I can putmy own studs in as I can get access to the back of the wall if that makes sense. Would it just be a case of adding my own support then drilling through they mouthing ect...any DIY buff's in the Dudley/wolverhampton area??
Member252055
Hi. You can get a stud detector from maplin or screwfix for around a tenner. The other way is to knock the wall lightly with your knuckles and you can hear when you get to a stud because the sound gets tighter. Once you have a rough idea then you can knock a couple of small tacks in to find the exact point of the stud; if you hit the stud with the tack then it'll feel hard, if you miss then it'll feel loose. You can then fine tune using this method and mark where the studs are.
Regards
Graham
