Wall mount for Toshiba LCD
Discussion in 'Home Cinema Buying & Building' started by daveb975, Oct 22, 2004.
  1. daveb975
    daveb975
    Oct 25, 2002
    4,367
    103
    London
    +375
    I am considering a Toshiba LCD - either the 26WL46, or the newer 27WL6.
    Does anyone have one of these units wall mounted. I am assuming that the VEDA Z846 mount will suit (see link below), but could anyone confirm this?
    www.superfi.co.uk/index.cfm/ page/moreinfo.cfm/Product_ID/1810
  2. bobby1amp
    bobby1amp
    Jun 8, 2004
    17
    have the 26wl46 myself and am looking for a tilt/turn wall bracket, the info on the veda model doesn't state a maximum load. ( the tosh is about 23kg ) . you might want to check first.
  3. daveb975
    daveb975
    Oct 25, 2002
    4,367
    103
    London
    +375
    Thanks. I didnt realise that the Toshiba was so heavy - my 42" plasma only weighs 29kg!
  4. daveb975
    daveb975
    Oct 25, 2002
    4,367
    103
    London
    +375
    Bobby - did you get a mount for your Toshiba? Do you know if this set has the 75, 100 or 200 VESA pattern?
    I have ordered the Veda one, I guess I will have to wait until it comes to see what the weight limit is.
    I notice that the slightly larger Veda ones do quote a weight limit of 30Kg - I hope this is same for the smaller ones.
    I think the mount you may be after if the Veda Z849 - tilt and turn with a 30KG limit, and should be about £90.
    Still unsure why the Toshibas are so much heavier than other manufacturers LCD's. I have noticed that the new 27WL46 is only 15.5KG compared to 21KG for the 26WL46.
