Wall Mount for Toshiba 32WL46
Discussion in 'Home Cinema Buying & Building' started by rnsdm001, Nov 12, 2004.
  1. rnsdm001
    rnsdm001
    Hello!
    I am buying a Toshiba 32WL46 32" LCD TV.
    I would like to mount this on the wall. I would like the mount to be able to swivel & tilt. I believe the TV weighs in at around 25kg.
    Could anybody give advice on any wall mounts that meet the specification?
    Many Thanks
    :lease:
  2. Flashman
    Flashman
    Dec 3, 2002
    353
    Swindon, Wilts
    +11
    I've got one of these, but not yet up on the wall. Try one of the forum sponsors www.leconcepts.com and click the LCD link and then Toshiba.
    They list three suitable brackets, a Vivanco one at £129.95 or a tilting Toshiba one at £249.99 (ouch) or a fixed Toshiba one at £39.99...
    Hope this helps,
  3. Orsky
    Orsky
    Nov 3, 2004
    22
    I bought a bracket for around £50 for my Sharp 32" LCD from these guys at www.chaseavdirect.co.uk. They were very helpful and should be able to point you in the right direction. The bracket I bought only handles up to 20Kg's (tv weighs 16.5) so is probably no good for you but they have loads to choose from and detailed descriptions which I found was a bit of a rarity when I was searching...
    Tony
  4. rnsdm001
    rnsdm001
    Thanks for the help guys. Ive dropped them an email to see if they can help further. Cheers
    'Flashman' How do you find the TV? Am I going to be pleased with it?
  5. Flashman
    Flashman
    Dec 3, 2002
    353
    Swindon, Wilts
    +11
    I can only go on my own experience, but I have been very, very pleased with mine.....Lord of the Rings (Just as an example) looks cracking, with loads of detail. I haven't seen any motion blur or anything like that and it copes well with dark scenes...
    As I've mentioned in other posts, give it a good signal and it's great, if you have a poor terrestrial signal or a weak Sky channel, then it will show up them for what they are......poor.
    Enjoy it!
