wall mount for the TX32LXD70
Discussion in 'Home Cinema Buying & Building' started by fxytimi, Sep 7, 2007.
  1. fxytimi
    fxytimi
    Apr 2, 2007
    157
    +9
    ok, i have a brick supporting wall, and i need a wall mount for the TX32LXD70 tv, which one should i go for, i want at least a variable tilt, i have around 60 pounds to spend. any suggestions? ho will i know which vesa mount to get?
  2. Member 209117
    Member 209117
  3. fxytimi
    fxytimi
    Apr 2, 2007
    157
    +9
    oh thank you, i shall be buying them! :D
  4. r3nu4l
    r3nu4l
    Jan 5, 2007
    90
    +4
    Hi fxytimi,
    Did you ever buy this mount? Did it work out okay? I have exactly the same TV and want to mount it on my chimney breast.
    Cheers.
