rinconmike
I just got a Samsung UN65JS8500 and want a full motion pull out wall mount so I can pull the tv off the wall and rotate it to see if from the adjacent room. I also want a mount that is easily adjustable when installing such as being able to do fine adjustments of rotating the screen to make sure it is level.
TV is specified at 61 pounds. It is going on a wood stud wall. I had a 45" sharp from 2003 with a pull out mount but this mount does not allow easy adjustments (cannot rotate left right to level tv and tilting forward is not easy) so I do not want to use it.
Looking online, I found the Sanus VCF532 but this model is only sold at Best Buy and is not cheap. Sanus has another model but does not seem as nice.
Can anyone recommend a good mount or is this Sanus the best option?
thanks,
Mike
thanks,
Mike
