Wall mount for Samsung LW26A33W
Discussion in 'Home Cinema Buying & Building' started by avv092, Nov 11, 2004.
  1. avv092
    avv092
    Can someone recommend a suitable wall mount for Samsung LW26A33W
    Vesa 200mmx100mm standard, has to be "turnable" similar to this:
    http://www.vogels.com/en/consumer/pages/proddetail.asp?id=8310024
    Also, the panel weight is 15kg with stand, will a wall mount for up to 15kg be ok? (the tv will obviously be mounted w/o stand, so should be slightly under 15kg)
