wall mount for pv500
Discussion in 'Home Cinema Buying & Building' started by Andy130, Jul 11, 2005.
  1. Andy130
    Andy130
    Mar 17, 2005
    784
    28
    St Helens
    +39
    Hi. Could anyone tell me where i can get a wall mount for a 42pv500 please
    cheers
    andy
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    I have one from RGB direct, it allows you to tilt the plasma on its top bar so you can get your wires connected once on the wall. I found this very useful, it is also very solid. It is £160 though.
  3. stroppygoblin
    stroppygoblin
    Jun 2, 2005
    186
    Mal, been meaning to ask you this, Can you do this lifting/connecting thing on your own? Or do you need 2 people? I am reluctant to try it flying solo and Mrs Goblin refuses to take responsibility :mad:
    If I unscrew the locking bolts, is it a one man job to just lift it free of the bottom slot? again as a solo activity can I then swing it up and add new connections?
    thanks in advance (and apologies to Andy for the thread hijack :hiya: )
  4. Andy130
    Andy130
    Mar 17, 2005
    784
    28
    St Helens
    +39
    Bloody typical :D
    Yeah, think im gunna go with the one from rgb, unless anyone else
    knows of a cheaper one.
  5. Avi
    Avi
    Dec 30, 2004
    13,963
    +2,063
    Andy
    I have a TY-WK42PV3W which is the official Panny mount for the PV500. There are like rocking horse ****. I bought this but ended up using the PED (long story) these cost about £299. It's boxed and used and your for £220 if your interested.
  6. Andy130
    Andy130
    Mar 17, 2005
    784
    28
    St Helens
    +39
    Cheers Daz, but thats a bit more than i wanna spend for a wall mount.
    Ive heard good things about the rgb ones though and will prob opt for that.
    fanks though :thumbsup:
  7. av2diefor
    av2diefor
  8. orange66
    orange66
    holy cow guys, I want one, but my 42 incher is over 40 kilos, thats a lot to trust to a cheap wall mount. How safe are they?
  9. Andy130
    Andy130
    Mar 17, 2005
    784
    28
    St Helens
    +39
    The ones from rs100 dont fit the pv500 unfortunately
  10. e_python
    e_python
  11. Dave
    Dave
    Jul 3, 2005
    11,497
    163
    +3,401
    If it fits, which I think it does. Av sales are doing a tilting mount for 99 quid including delivery.
    You should be able to connect everything up when it's on the wall because the screen hangs off the bar at the top and the quality is great.
    The link is at the top of the forum page.
  12. AV killed my CC
    AV killed my CC
    Jan 3, 2002
    41
    +3
    I mounted my PV500 on an RS100 wall mount this weekend :)
    As long as you have the extra depth bars if fits fine and needs no spacers. Simple straightforward mount but does the job. Although unlike the RGB one doesn't allow to tilt and put cables in after it is up. (Bizarrely got the panel from RGB and with Ped stand, another long story)
  13. lack300
    lack300
    Feb 25, 2005
    1,467
    Bedford
    +46
    how about my Unicol bracket i have on for sale thread. very good quality. it held my 50" panny on the wall no probs and the 42" aswell.
  14. Crazy Paul
    Crazy Paul
  15. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    My missus helped me lift it on, I connected the wires, then I lifted it that extra inch myself to get it in the bottom slot.
    Because the top slot is longer it will slide in to the bottom slots without it falling off the wall. As long you are not a weakling. :smashin:
