Quantcast
Question Wall mount for Panasonic TH-42PZ80BA
aopskeletor
Bought a wall mount off Amazon (VonHaus 32"-70"), put the bracket on the wall, attached the arms to the TV and... the arms are too wide for the bracket.
I'd stupidly assumed that the mounting holes on the TV were a typical VESA one.
Easy option would be to buy another one of the same mount so one arm rests on each bracket but it'll mean that the sides of the brackets will show outside the frame of the TV. Other option is find a bracket that is wide enough (can't find my measuring tape, think the mounting holes are around 800mm apart).
