wall Mount for LGRZ42PX11?
Discussion in 'Home Cinema Buying & Building' started by jeffnail, Aug 24, 2005.
  1. jeffnail
    jeffnail
    Dec 29, 2004
    29
    London
    New LG being del on Friday, ordering a titl wall mount from av sales, what have other LG owners used to wall mount their plasmas and do I need to pay £300 for an insaller to come in and put it up onto the block/brick wall?????
  2. absthechatter
    absthechatter
    Nov 27, 2004
    159
    I have very limited DIY skills and put my bracket up in about 10 minutes and it holds my weight, let alone the plasmas. I have not tried the AV Sales bracket, but mine was a very cheap bracket and works fine, so you should have no problems.
    If you was that uncertain, it would not cost you £300 to get one done for you, even somewhere very expensive like Comet only charge £200, and that includes a £100 bracket. Someone in one of your local papers that offer DIY will probably do it for £20-£30, but to be honest, it's quite easy unless of course you want to start chasing out walls etc......
  3. jeffnail
    jeffnail
    Dec 29, 2004
    29
    London
    Thanks for your reply, what srews and fixing items did you need or did it all come with the wall mount.
  4. absthechatter
    absthechatter
    Nov 27, 2004
    159
    Mine all came together. I am trying to remember the name of the bracket, it was only a cheap one, I am pretty sure it began with the letter V, something like Vivanco??? There was a choice of fixings depending on what type of wall you wanted to fit it to.
