KHousein90
Established Member
Hi I have my Sony vw300es wall mounted, the mount doesn't seem to hold up well to the size and weight of the projector as the arm the projector is connected to seems to bend slight leading to an uneven image, any rock solid brand mounts out there that can keep this projector firmly in place ? Has to be wall mounted no curling mounts
