Wall mount for FP241W
Discussion in 'Home Cinema Buying & Building' started by thecremeegg, Jan 23, 2008.
  1. thecremeegg
    thecremeegg
    Jul 15, 2007
    28
    +32
    I am looking for a relatively inexpensive wall mount for this monitor, but i'm completely unsure of what do get.
    Apprently its VESA compatible, but I dont know what that means and every mount i see on the internet seems to have a different shape fitment to the back of my monitor :confused:
    Anyone recommend anything?
  2. Member252055
    Member252055
    Jan 23, 2008
    1,850
    83
    Nottingham
    +290
  3. thecremeegg
    thecremeegg
    Jul 15, 2007
    28
    +32
    Thanks for that. Does it matter that my monitor is 24" when it says up to 21"? i suppose its lighter than the equivalent sized television?
    Could you possibly find one that tilts/swivels? Would be much appreciated
  4. Member252055
    Member252055
    Jan 23, 2008
    1,850
    83
    Nottingham
    +290
  5. thecremeegg
    thecremeegg
    Jul 15, 2007
    28
    +32
    Ah ok, cheers. Just have to find out if its 75 or 100 now
  6. Member252055
    Member252055
    Jan 23, 2008
    1,850
    83
    Nottingham
    +290
    It doesn't matter, this bracket and most brackets of it's size/type will fit both 75 and 100 VESA.
