Wall Mount for Acer AT3201W
Discussion in 'Home Cinema Buying & Building' started by vipergrm, Sep 12, 2005.
  1. vipergrm
    vipergrm
    Sep 6, 2005
    3,799
    Belfast
    +578
    Hi guys, new to the forum! :hiya:
    Just bought an Acer AT3201W from Dabs with 32"THIS wall mount, then I realised that it might not fit! Can anyone tell me what size the Acer is? If this won't fit, where can I get the correct wall mount?
    Many thanks in advance! ;)
