Wall mount for 40" LCD
thelurch
Im still trying to work out which type of bracket is suitable for my 40" samsung, It needs to be Vesa 200mm compliant, and im not fussed if it tilts or not,
There are two types I think I have pinned it down to:
http://www.morpethmobiles.co.uk/proddetail.asp?prod=MM750-W11f
and
http://www.chaseavdirect.co.uk/acatalog/Large-LCD-VESA-200-100-Wall-Mount-Bracket-UNI-05.html
Can I expect the brackets to come with the screws to fix the bracket to the TV? as the holes on the back of the TV I believe are a universal size?
hughesy
there is an omnimount one that will work too. I think there are a bit more expensive though.
You can get models that are static, tilt or articulate...
http://www.omnimount.com/
Not sure where to buy them though (other than DSG stores[expensive])....
