wall mount eggs
Discussion in 'Home Cinema Speakers' started by philthyanimal, Jan 21, 2004.
  1. philthyanimal
    philthyanimal
    I'm about to upgrade my current speaker set up to a set of kht 2005's and was wondering if they a wall mountable. If so do i need extra brackets or are the bases on them the brackets.
  2. jmack
    jmack
    some wall mounted eggs
    pic taken from plasma thread(howies)
  3. balders
    balders
    Jul 31, 2001
    451
    28
    +25
    The eggs have slots in the bottom of their stands to allow them to be wall mounted using a couple of screws. The stand can be connected to the bottom of the speaker for stand-mounting, or the back for wall-mounting (as in jmack's pic)
    There's even a paper template in the instruction booklet.
    Balders.
  4. philthyanimal
    philthyanimal
    thanks.
    One last thing before i take the plunge.
    Would the 2005s be ok with the kef 1001 sub?
