Wall Mount Cables
Discussion in 'Home Cinema Buying & Building' started by ecnirp, Oct 23, 2004.
  1. ecnirp
    ecnirp
    Sep 10, 2002
    30
    9
    I am planning to get a 42" plasma, probably a panasonic, and then wall mount it.
    With it being a focul point of the living room, how do people hide the cables going into/out of the wall mounted plasma's?, normally all this stuff is hidden behind the TV/stand on a CRT, but on a wall mounted plasma how do you hide the cables for Scart DVD/Scart AMP/Aerial/Power lead etc?
  2. moku
    moku
    Sep 19, 2004
    88
    Manchester
    Wall mounting the plasma is great but with difficulties such as hiding the many cables, and making sure that the wall is strong enough to carry the weight of the plasma, and you need another pair of hands to help with hanging the plasma on the wall due to the weight. DO NOT ATTEMPT THIS ON YOUR OWN!
    The best way to hide the cables is to chisel a groove in the wall and bury the cables in the groove and the plaster over it. Doing this will certainly require redecorating etc and not to mention the inconvenience.
    Having said all the above, I still believe that plasmas look awesome wall mounted, but you will need to do some groundwork and grafting!
  3. vileda
    vileda
    Oct 15, 2004
    401
    Sunderland, Tyne & Wear
    If you go down the route of plastering cables into the wall remember that any change of cable requires redecoration.
    I'm about to go the route of putting a plasma (probably a hitachi 42pd5200) on a chimney breast and have come to the conclusion that the best way is to bury a 1" pipe in the wall to take the cables.
    That way if I upgrade to some new super dooper digital cable in 10 years I don't need to pull half the wall down just pull a new cable through the pipe.
  4. ecnirp
    ecnirp
    Sep 10, 2002
    30
    9
    I was thinking along similar lines vileda, cables generally do not fail, but burying them in the wall sounds abit risk if they do!!, problem with scart leads is that the connectors are so big, pulling them through a pipe could be abit problematic!!
  5. vileda
    vileda
    Oct 15, 2004
    401
    I'm a great believer in sods law.
    I've discounted using a scart lead and will just use Component & s video, the 42pd5200 has 2x component &, 1x s video & pc
  6. Venger
    Venger
    Is there no form of 'trunking' that can be used? i.e. bundle all the cables together and cover them with a rigid piece of plastic. This can then be screwed on to the wall and painted the same colour as the rest of the room. It's not ideal but would just about work I think and involve a bit less upheavel than pipes and chisels.
    I'm about to go down this route but need to find the 'trunking'.
    Any ideas where I can get this?
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    there is loads of types of conduit you can use....... paintable plain white brushed ALuminium.....loads mate have a search round B&Q and some other places
  8. Johnnypanic
    Johnnypanic
    Aug 4, 2004
    201
    +16
    A bit of plastic wastepipe, cut in half and affixed to the wall, then paint in whatever colour you require.
    Should work, but I'll let you know later this week when I do the job :)
    Johnnypanic
  9. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Some good ideas here, but an even better one is never to use a scart lead up to the screen. They have a monotonous habit of working loose, let alone the plug size and the fact that they are not the best for the kind of cable length typical of a wall mounted plasma.
