Wall Mount Bracket for Sharp 37" LC37HV4E
Discussion in 'Home Cinema Buying & Building' started by jimbrett, Jan 6, 2005.
  1. jimbrett
    Hi Guys,
    I know there are a couple of other threads covering wall mount brackets for LCDs etc. but i wanted to be a little more specific about my requirements.
    Its for the above 37" LCD tv which weighs 20Kg (ish), I dont need the adjustable arm just the basic tilt mechansim. I dont mind an arm as long as when the the TV is pushed back against the wall it sits as flush as a bracket without the arm - does that make sense.
    I see sharp do one for £130 direct, but there are no pictures - anyone have any? also seems a bit steep for a bracket???
    The TV is VESA 200 (i.e. 4 holes 200mm apart etc).
    Thanks for any help
