Wall inset for 435XDE. How much breathing space?
Discussion in 'Plasma TVs Forum' started by yellowpostit, Aug 16, 2005.
  1. yellowpostit
    yellowpostit
    Jun 27, 2005
    177
    19
    Nottingham
    I'm drawing up a plan for our builder to build a false chimney breast (i.e, no fire, just for show) with an "inset" for the 435XDE.
    We want the screen to be flush with the chimney breast, hence the inset. All cables are being buried.
    I know I need some breathing space around the panel, but how much? The operating instructions don't really say anything specific (thanks Alan A, it was still handy though).
    I was thinking a 2-inch border all the way round.
    Anyone any ideas?
  2. Setch
    Setch
    Jan 31, 2005
    81
    9
    I have mine hung on the wall and totally boxed in. I have about 1/4" gap all round the plasma. Behind the panel is a gap of about 90mm which narrows to about 20mm at the top where the DVDs are. I have not had any problems with it overheating, I would say that it the panel is the same temp as when it was mounted on a stand.
    http://www.avforums.com/forums/showthread.php?t=78824&page=122&pp=15
    I think that provided you have a ventilation slot somewhere at the top of false wall, then you should be ok with a minimum gap around the panel.
    Setch
  3. Badger0-0
    Badger0-0
    May 30, 2005
    20,593
    Spaghetti Junction (really)
    +1,921
    I wouldn't recommend that.
    My 7200 manual says 4" (100mm) all the way round.
    Electronics don't like heat.
    I say vents top and bottom, preferably with a reasonably powerful fan is best.
    It would act like a chimney then :thumbsup:
    That's what happens if you don't enclose a telly.
    Slots on the top is good, but you need to draw cool air in too.
    That way, you could have it fitted fully enclosed.
    I think this needs researching though, because it's a popular question.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,581
    The Borders
    +3,030
    Hello all
    If there is no free air (forced or convection) at the rear of the Display you require an 'ingo' that's approx 50mm (Left, Bottom and Right) and 200mm (Top) larger than the Area of your Display.
    The 'tight to the bezel' look is very nice (assuming you do have Free air flow at the rear of the unit) but you do have to work out how to get the display on and off its wall mount :)
    Best regards
    Joe
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I've got several installs like this, vented top and bottom with free flow behind the false wall. That's easy if you are just starting to build it, and you could also consider in wall speakers with enclosures to the spec on makers web site. The way to get it on and off the mount is with a swing out bracket. It makes connecting the cables possible too, otherwise that's a nightmare. The only other way I can think of to do this is with removable panels, I've done this in 1 commercial and 1 ultra modern residential install, nice if you like that kind of thing. It wouldn't work in my 1930's house if you see what I mean.
  6. yellowpostit
    yellowpostit
    Jun 27, 2005
    177
    19
    Nottingham
    Yes, the mounting issue was a concern at the back of my mind.
    If I had a 4" gap all the way round, and then a 'chimney' type opening above the top, would that do?
    And if that was okay, 4" would still be a problem when getting it onto a flat wall mount?
