Wall brackets?
Discussion in 'Home Cinema Buying & Building' started by simonali, Nov 24, 2004.
  1. simonali
    simonali
    Jul 5, 2004
    61
    I've just bought a 17" Toshiba LCD TV and want to mount it on the wall in the kitchen. Are there any flat or 10 degree tilting brackets available that have some sort of cable tidy either built in or available as an optional add-on. The TV will be mounted right above the power and aerial sockets but just having the cables hanging out the bottom is not gonna make the missus happy!
    Anyone else had this problem and come up with the goods or a neat solution?
    Cheers :beer:
    Simon
