mrmcdean
Im close to getting a Panny LXD70 32" and would like to mount it in the corner of my lounge (like a corner TV unit only higher) as we dont really have anywhere else to put the screen thats sensible. Ideally its going to cut accross the corner with a couple of shelves below / above for AV kit with cables running down the back. Rather than getting a swing arm bracket I thought id ask my dad to make a bracket to do the job (Luckily he owns his own engineering company).
Problem is ive never owner flat panel screen so have no idea if this is a logical idea. Would it be difficult to get the correct screws to attach the 'home made' bracket to the screen etc., are these brackets that you can buy some amazing engineering feat that im not aware of ? My boss recently purchases a Lowe LCD and paid £50 for a piece of bent metal with some holes drilled in it.
Or am I better of looking at other options.
