Wall Bracket Needed
Streetrod
Hi all, after a lot searching I have decided to buy an Infocus 7210. At the price I have paid it was too good a deal to miss. Anyway I would like to mount the projector on the back wall. Does anyone know of a wall bracket that would fit? If not I might have to make my own.
madgames
Use an Argos microwave bracket , available in silver or white or just make a shelf
Argos numbers if interested :
White 8414715
Silver 8405391
ZippyCat
What ever you do don’t but the Vogels wall bracket; the build quality leaves a lot to be desired, especially when you consider the price.
Streetrod
Thanks for the suggestions, the more i think about the more I think I could design something more stylish in steel myself. Sounds like I need to head to my garage and fire up the mig welder. I have drawn a couple of ideas that look good. I will keep you informed.
