Wall bracket for the JVC LT26DS6BJ
Discussion in 'Home Cinema Buying & Building' started by Tony_R, Sep 8, 2005.
  1. Tony_R
    Tony_R
    I finally ordered myself the JVC LT26DS6BJ LCD TV yesterday. Should hopefully get it next week.
    Though I did not order a wall bracket at the time as they seemed quite expesive £70+
    Is there anywhere you would suggest who sell cheap wall brackets? And what exact wall bracket would I require for this TV?
    Thanks.
  2. Tony_R
    Tony_R
    Sorry to bump this up, but does anyone know the answer?
    Thanks.
  3. MDPlatts
    MDPlatts
    Aug 20, 2005
    276
    2nd City - Manchester, UK
    +21
    Would you trust your latest £1K-£1.6K purchase to a cheaper wall bracket - or use shorter screws or omit the proper rawlplugs? I wouldn't. £70 sounds fairly cheap IMHO - but so long as they say its the model for what you got and warrant it to not break then its your best bet.
    M.
  4. Tony_R
    Tony_R
    Ok fair enough I will pay that then, I don't mind I just though that it was quite a lot. Obviously I was wrong. Thanks.
