Wall Bracket for Plasma
Discussion in 'Home Cinema Buying & Building' started by bass007, Oct 27, 2005.
  1. bass007
    bass007
    Apr 8, 2004
    1,514
    london
    +36
    I need to wall mount My LG Plasma, I am not sure which bracket to go for? The screen is 42" I need it o be able to tilt and if possible move forward and backwards not sideways. I don't really want to spend too much say £150, I was looking at the Omnimount CL-X Cantilever Mount but I think its about £500 is there an alternative? This is fairly urgent as I need to order it by Midday today, has to be fixed on the wall by sat evening
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    all mounts that are that clever are a bit pricey, sorry.
  3. Dan L
    Dan L
    Feb 7, 2005
    2,204
    Wotton-under-Edge
    +110
    I looked at cantilever mounts originally and gave up on the idea due to the cost. I guess when you think about the stress the arm would be under holding a 42" screen, you kind of expect it to cost a fair bit.
  4. bass007
    bass007
    Apr 8, 2004
    1,514
    london
    +36
    is there one which is just tilting well built and under £150?
  5. bass007
    bass007
    Apr 8, 2004
    1,514
    london
    +36
    Or bracket anyone on here uses and is happy with
  6. Dan L
    Dan L
    Feb 7, 2005
    2,204
    Wotton-under-Edge
    +110
