Wall bracket for Panasonic TX32LXD1?
Discussion in 'Home Cinema Buying & Building' started by Zcubed, Oct 10, 2004.
  1. Zcubed
    Zcubed
    Hi All,
    I am having a great deal of problems trying to find a wall bracket to fit the Panasonic TX32LXD1 LCD TV. Panasonic do not seem to have any in stock and I'm completly lost amongst the universal type.
    Is there anyone or may already be using one successfully or who can suggest a suitable type. All I want is the fixed close coupled wall type.
    Apologies if this has been asked before,
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  3. Zcubed
    Zcubed
    Top advice, ordered one and fits beautifully!
    Cheers :)
  4. daveb975
    daveb975
    Oct 25, 2002
    4,392
    103
    London
    +377
    Which one did you go for - the only ones I can see on the site only go up to 15KG max capacity.
