Wall bracket for Panasonic TX32LXD1
Discussion in 'Home Cinema Buying & Building' started by Zcubed, Oct 10, 2004.
  1. Zcubed
    Zcubed
    Hi All,
    I am having a great deal of problems trying to find a wall bracket to fit the Panasonic TX32LXD1 LCD TV. Panasonic do not seem to have any in stock and I'm completly lost amongst the universal type.
    Is there anyone or may already be using one successfully or who can suggest a suitable type. All I want is the fixed close coupled wall type.
    Apologies if this has been asked before,
  2. fuji
    fuji
    Jun 10, 2004
    41
    I have the 26" version of your tv (26-lxd1), and managed to get the wallbracket from http://www.unicol.com (which is where Panasonic referred me too). Give Unicol a ring and they will sort you out. Hope this helps.
  3. Zcubed
    Zcubed
    Top advice, ordered one and fits beautifully!
    Cheers :)
