wall bracket for LGRZ42PX11
Discussion in 'Home Cinema Buying & Building' started by steve p, Jan 19, 2005.
  1. steve p
    steve p
    Hi there , can anyone recommend a decent but not incredibly expensive flat wall mounting bracket for this plasma screen . ?
  2. mike.jones
    mike.jones
    Dec 27, 2004
  3. vectrasri99
    vectrasri99
    The R100 fits and is about 22mm from wall so well slim.
  4. steve p
    steve p
    Thanks for both the above suggestions ..... who makes the R100 by the way ?
  5. mcbeal
    mcbeal
    Jan 21, 2005
    10
    the wall brackets are supplide with it, you just take the stand off and use the wall brackets
  6. googlybear
    googlybear
    Nov 10, 2004
    169
    16
    if you look on the LG thread at about page 40ish i posted the website of a mount dealer on there. It is the one i have and is very good and does not block the scart sockets on the rear of the screen
