Wall bracket for LG OLED65B7V
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by drdes, May 26, 2018.
  1. drdes
    drdes
    May 16, 2008
    246
    +9
    Looking for a wall bracket for my LG OLED65B7V. The TV will be going into a recess into the wall with only 25mm on each side/top/bottom. So TV will need to be able to be pulled straight out before being turned. Can anyone tell me if this one is suitable:
    https://www.amazon.co.uk/gp/product/B01AYBLPNA/
    Richer Sounds have suggested the following:
    Sanus 42 - 90 inch Cantilever TV Bracket
    But £179 vs £40 is a big difference - and surely they do the same thing?
    Any advice or alternatives I should be considering?
  2. Roohster
    Roohster
    Jul 1, 2004
    4,433
    7
    Derbyshire
    +5,063
    I just bought the one you linked to on Amazon.
    I haven't installed it yet (literally just arrived) but it's a really solid piece of kit and gets rave reviews.
    Many owners suggest ditching the supplied wall bolts in favour of Rigifix fastenings.
  3. drdes
    drdes
    May 16, 2008
    246
    +9
    Which Rigifix fastenings? Can you provide link to Amazon?
  4. Roohster
    Roohster
    Jul 1, 2004
    4,433
    7
    Derbyshire
    +5,063
