Wall Bracket for KRP 500A
Diinky
Hi All
Can anyone recommend a good, very strong wall bracket for my KRP500A?
Needs to be a tilt and swivel bracket as going on wall in the corner of the room.
thanks
Timmy C
I've had a 50" Kuro on a Vogels swing arm mount for the last 6 years and it's not been a problem so far. They don't make the one I have any more but it might be worth looking to see if they still do one that will take the weight of a plasma. Might also be worth seeing if Unicol still make a suitable one.
SaajanB
I've found that Hama full motion brackets are pretty good. If you've got the budget, get a unicol bracket. I picked one up recently for my 600M and it is really quite solid.
