Wall bracket for 55inch OLED lg
Discussion in 'OLED TVs Forum' started by Ld1978, Nov 6, 2017.
Tags:
  1. Ld1978
    Ld1978
    Nov 5, 2017
    63
    Hampshire
    +18
  2. Anton2015
    Anton2015
    Jul 8, 2015
    5,968
    wickford
    +3,669
    Remember with an LG Oled the fixings are at the bottom of the screen and not in the more traditional centre.
    It going to look very different to the pics on that link.
    Do you need a tilting bracket?
    Not sure if you have to buy a bracket from JL to use their service but if not look at sites like the plasma centre which do loads of brackets.
    I’ve always liked the brand Ultimate Mounts as they do strong, sturdy brackets but they don’t look as fancy etc as some of the other brands.
    In the manual for the TV it usually states which bracket LG have that’s for the TV - some are available in the U.K. some don’t seem to be but it worth checking out.
  3. Ld1978
    Ld1978
    Nov 5, 2017
    63
    Hampshire
    +18
    Thanks so much :) yes for John Lewis installation it has to be their bracket.
    I’m now thinking with the currys code to go for the c7 as the black trim is nicer and then maybe find someone local to install (which means I’ll look for a bracket where you suggested)
  4. Anton2015
    Anton2015
    Jul 8, 2015
    5,968
    wickford
    +3,669
    Sounds like a better option! :)
