Wall and Ceiling Mounts
Discussion in 'Home Cinema Buying & Building' started by blued, Nov 26, 2004.
  1. blued
    blued
    Nov 25, 2004
    34
    I've just bought a 42" LG Plasma and have been having a look around the forum for mounting options. The screen is far too big to be sitting on a table considering the size of my room so I think I'm going to have to have it mounted on the wall or the ceiling. Its a small room, 3.5x4 I think.
    I think that it would look better mounted on the wall but if I was to mount it on the ceiling I'd have the option of tilting it horizontally aswell as vertically. I've seen wall mounts that tilt vertically, are they also available with horizontal tilt?
