Wall aerial to panel.
Discussion in 'Plasma TVs Forum' started by TVplease, Mar 25, 2006.
  1. TVplease
    TVplease
    I ahve sky in my living room, and can watch it in the bedroom, through the normal TV aerial (whatever its called - yo know the round one in the wall) as it has been wired to do this. Now, if I get a panel for my bedroom, how do i connect it to get this sky signal? Would I just attach a freeview box to the panel, and then plug the freeview box into the wall aerial? Would this allow the sky signal to go through it and be displayed on the panel?
    Any help much appriciated!! :thumbsup:
  2. Bacus
    Bacus
    Dec 30, 2004
    8,995
    Close to the sea
    +2,925
    Depends on what panel you get ? Some panels have built in tuners, if you get one of these then you only have to plug the aerial lead into the back and away you go !! Really need more info about what panel you intend to get !!
  3. TVplease
    TVplease
    I was meaning panel in terms of a screen with no built in tuner. Is this incorrect? Sorry I dont know a huge amount. It would be a panasonic commercial panel, pwd6/7/8 not sure yet...
    Cheers.
  4. Bacus
    Bacus
    Dec 30, 2004
    8,995
    Close to the sea
    +2,925
    if you are going to use a panel only display then i think the best way would be to connect your aerial lead into a video player then connect vid to panel !!
  5. TVplease
    TVplease
    Thanks mate, just happy to know it can be done! :D
  6. Bacus
    Bacus
    Dec 30, 2004
    8,995
    Close to the sea
    +2,925
    you can use a video or recordable dvd playes as a tuner !! if your getting a panasonic panel you might be able to get an RF card to go into one of the input boards on the back of the screen
