w800i transferring music.
Discussion in 'Mobile Phones Forum' started by s1hastie, Sep 11, 2005.
  1. s1hastie
    s1hastie
    Apr 10, 2005
    2,505
    68
    +39
    Ok I don't know if i'm doing something wrong but i'm having problems with the disc2phone software. It keeps putting music in "unknown artist" folders. Or for example I have a 3cd album to put on there it will put them in 3 seperate folders but what i want is to have them in 1 folder with 3 subfolders.
    Anyway I thought I could get round this by going to my computer opening up the removable disk F: and moving the files around creating new folders etc.
    Now when I try to get the phone to play them it won't because I didn't use the disc2phone software!!
    Going crazy here please help.
  2. s1hastie
    s1hastie
    Apr 10, 2005
    2,505
    68
    +39
    Ok i have made some developments on the above, found that I can play the tunes but not through the walkman part of the phone I have to go into filemanager then sounds etc
    Is this how it has to be? or is there a way round it or any 3rd party software that I can use?
  3. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    make sure the ID3 tags on your MP3's are correct as the phone's mp3 player will use these to organise them rather than the file names
  4. PaulJ
    PaulJ
    Are you connected to the internet whilst transferring the music?
    If you are connected, the program automatically finds the album titles, i have downloaded a 3 disc cd and it split it into the way you wanted, with 1 folder and 3 sub folders.
  5. PaulJ
    PaulJ
    Hope this helps. :smashin:
  6. s1hastie
    s1hastie
    Apr 10, 2005
    2,505
    68
    +39
    Cheers Paul I will give it ago.
  7. RMCF
    RMCF
    Aug 24, 2000
    7,420
    +737
    Had this phone for a few days now and very impressed with it.
    Today was the 1st day I started to transfer some of my CD collection to the phone. Noticed a couple of things that I didn't like.
    1) If you are transferring more than 1 CD from a single artist its automatically creates folders for each CD. Thats fair enough. But I just wanted to have all the artists' tracks together. So I deleted the 2 x album title folders, leaving all the MP3 tracks in the level directly beneath the top level. When I tried to listen to them, the phone did not see anything under the top level. It looks like there must be at least one subfolder for the phone software to work.
    2) I have been playing the phone through the loudspeaker for approx 45mins and the brand new battery went from 100% full to 75%. Very sore on battery. If you were on a long journey you will flatten the battery!!
    Otherwise an excellent phone.
  8. ParmMann
    ParmMann
    Dec 6, 2004
    946
    28
    +50
    I think the best way to organise your MP3's is manually.
    If you go onto the removable drive, double click on the MP3 folder.
    In this folder, create a folder for an artist, then a subfolder for the album name, and then put your MP3 tracks in that.
    I found that I wouldn't be using full albums so I've made folders along these lines:
    ../MP3/Various Artists/Pop/
    ../MP3/Various Artists/Rock/
    ../MP3/Various Artists/Soundtracks/
    or even
    ../MP3/John Lennon/Various Tracks/
    With these folders, you should have 'Various Artists' and 'John Lennon' listed under the walkmans Artists list. You should have 'Pop', 'Rock', 'Soundtracks' and 'Various Tracks' under the Albums list.
    Hope it helps! :thumbsup:
  9. RMCF
    RMCF
    Aug 24, 2000
    7,420
    +737
    Noticed another problem while playing with phone.
    If you record a video clip it is stored with a .3pg extension. When I go into my PC, I cannot view the clip. PC tries to go to web to download somwthing to play it. Can I not just use Media Player?
