W800i mp3
Discussion in 'Headphones, Earphones & Portable Music' started by suniil, Sep 3, 2005.
  1. suniil
    suniil
    Jan 24, 2005
    4,883
    London SE5 / W1
    +402
    Just ordered one and waiting for delivery.
    Would like to see others views on *walkman* factor. Also anybody knows the quality of headsets? Looks like an in-ear (canal) headsets comes along with this phone
    Many thanks
  2. IanPM
    IanPM
    Jan 12, 2004
    389
    +6
    I have a K700i, which also plays mp3s, although the stroage is very limited. The headphones that came with that phone are really quite good indeed. The headphones that come with the W800 look vert nice indeed.
  3. ca6leguy
    ca6leguy
    What's the difference between the W800i and the K750i models ? By the way, how is the sound quality compared to real walkmans ?
  4. lockers
    lockers
    Jan 31, 2005
    155
    High Wycombe
    +9
    From what I remember when I looked into it before I got my w800i, the main difference is the fact it comes with a quite reasonable size memory stick duo of 512Mb. I *think* the other major thing is the headset having the ability to change headphones, so you can use whatever ones you like (if they have the 3.5mm jack)
    On a side note...this 'Walkman' phone doesn't actually play Atrac/Atrac3plus, which is quite a suprise to me. You would think that they would of included this compatibilty given how much they pushed Atrac with their other walkmans, but nope! Whether they'll change this with a firmware release I don't know, but it would at least be nice to have the option of Atrac.
