w800i disc 2 phone HELP!!
Discussion in 'Mobile Phones Forum' started by s1hastie, Sep 2, 2005.
  1. s1hastie
    s1hastie
    Apr 10, 2005
    2,505
    68
    +39
    Ok so I just got my W800i. Have installed the software moved some tracks on to the transfer list. I have the phone connected but when I click transfer it says "No target device found. Please insert memory stick or connect phone via usb"
    The memory stick is in and the phone is connected as it is charging through the USB.
    Anyone else had similar problems? can anyone help. Main reason I got this phone was the walkman feature if I can't use that I might as well send it back.
  2. BenW
    BenW
    Jun 3, 2005
    888
    Stansted
    +17
    Don't use the software.
    Go into my computer and it will be in there as a removable device. Open it, go to the MP3 folder and copy into there.
  3. s1hastie
    s1hastie
    Apr 10, 2005
    2,505
    68
    +39
    Ben cheers I have sorted it. Dumb ****** that i am i installed the software but not the drivers lol.
    [Note from mods : please avoid swear words, thanks. :nono: Swear word manually removed. ]
