W/S Switching Signals
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Garrett, Sep 11, 2003.
  1. Garrett
    Garrett
    Apr 21, 2001
    40,739
    2
    167
    The best thief you’ll never see.
    +6,851
    Has any one noticed some channels are now sending out switching signals so video machine can record a film in anamorphic then auto switch the set to 16:9 on play back.
  2. Kevo
    Kevo
    Aug 23, 2001
    5,398
    Manchester
    +149
    I thought they always did :confused:
    For as long as I can remember, every 16:9 prog I record gets auto switched upon playback.
  3. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,268
    Manchester
    +757
    Of course it will only be recognised by receiving equipment that sees the WS flag , usually line23 WSS (Wide Screen Signalling).
    Chris Muriel, Manchester
  4. Garrett
    Garrett
    Apr 21, 2001
    40,739
    2
    167
    +6,851
    I have a Panasonic and it has never did it before. It does not work on old tapes that I have recorded in W/S, just the later ones, although I think JVC did have this function that worked on films transmitted in anamorphic W/S before.
    Also old tape still have PalPlus in the code.
