vx10
Discussion in 'Home Cinema Speakers' started by krusty, Dec 18, 2003.
  1. krusty
    krusty
    does anyone know what the crossover setting should be on a velodyne vx10 with mission 773e,s set at small. thanks
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    If you've set the Missions to 'Small', then I assume your AV amp is sorting out the crossover settings.
    With this in mind, just turn the crossover dial on the VX-10 as high as it will go, and let your amp do all the filtering (as it's probably better at it).
