S
Sjeffray
Hello,
I have a Sony VW HT 10 witch provided good service for 2 years (only arround 750 h). Since a few month the screen is spoiled in certain cases by (small) verical lines . The vertical lines does not appear on the total heigth of the screen; it appears only on the rigth position of important color transitions. For example if the image is composed of some big red letters on a black screen, the left part of the letters has a few lines inside (no lines at the right of the letter on the black... These lines disapear if the black of the screen turns to grey...). The color of the lines depends on the colours of the transition and the lines disapear if the transition of colour is smooth...
Sony could not give any explanation other than "change the mother board of the projector" witch appeared to cost 1700 Euro !!!
As someone already been confronted to this problem ?
I still want to believe that there is an other issue than "buying a new projector" after only two years of service.
Sjeffray
Sjeffray
