vw touran poor signal
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by pinky77, Aug 27, 2006.
  1. pinky77
    pinky77
    Aug 22, 2006
    4
    ive just fitted a panasonic dv2000 now i only get radio in few places it was ok with the standard radio any ideas thanks
  2. james_19742000
    james_19742000
    Oct 8, 2004
    666
    +18
    ON VW's there is an extra booster aerial thing that goes inline to the aerial socket if you replace the original head unit, it is inbuilt on the original VW unit, but its to do with it not having an aerial on display, believe teh aerial is in the window or something, there are a few sites that can supply what you need, do a search for some internet places that sell replacement head units and some of them will ask you for what car and you can see the accesories you will need to fit correctly.
    Hope this helps, James.
