Vsxd812/912
Discussion in 'AV Receivers & Amplifiers' started by rulocal, Nov 30, 2003.
  1. rulocal
    rulocal
    Jan 4, 2003
    1,147
    +47
    Can someone please explain the difference between the Multi-Channel Acoustic Calibration System Set-ups on the above two Pioneer amps, if any.
    Doing a comparison on the Pioneer site shows the 912 has 'Auto' but the 812 is 'manual'. Having a 'manual' auto-setup sounds like a contradiction. Am I missing something?
  2. JoeyJoeJoe
    JoeyJoeJoe
    On the 812, manual set up is just that, you have to callibrate all your speakers manually. Whereas on the 912, you plug in the supplied mic, push a button on the remote and after about 3 minutes, the jobs done for you. Quite a handy feature to have if you are not familiar with setting up your speakers. Me being lazy went for the 912 :)
