VSX2011S vs VA555ES
Discussion in 'AV Receivers & Amplifiers' started by hannanp, Aug 22, 2003.
  1. hannanp
    hannanp
    I'm planning to purchase either a Sony VA555ES or Pioneer VSX2011S. Does anyone have experience of comparing the two products?
    Both appear to be available for around £670 with a bit of hard searching.
    I have a KEF KHT2005 setup and will be attaching a Sony DVD player, Sky+ box and XBox.
    Paul
  2. Rob Sheep
    Rob Sheep
    Aug 17, 2003
    155
    16
    Worcester
    Try a Pioneer VSX1011s, it's cheaper than the 2011s, it just doesn't have the 'Air Studios' tuning (there is also little difference in the sound quality)and its better built than the Sony.
  3. ChrisNic
    ChrisNic
    May 11, 2003
    1,698
    48
    Thame
    +62
    I would have to say that the Sony is beautifully built. A step up from the Pioneers. Its is getting a bit long in the tooth now though, only 6 channels of amplification if that matters to you.
  4. stranger
    stranger
    May 29, 2003
    2,032
    5
    117
    Manchester
    +705
    I've had the Sony VA555ES since feb. '02 and it's an excellent piece of kit if you're ok with 6.1-and it's certainly of better build quality than the Pioneer (good as the Pioneer is)
  5. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    I agree, the Sony's build quality is hugely better than the Pioneer's, and to my ears it's considerably better in Stereo too.
  6. hannanp
    hannanp
    Not too worried about the 7th Channel, however I like the idea of the automated set up facility, it doesn't appear as if the Sony has anything similar. I believe I can set ths up manually with an SPL meter. I assume the Sony has a 'learning' remote too
  7. stranger
    stranger
    May 29, 2003
    2,032
    5
    117
    Manchester
    +705
    the Sony has a comprehensive code library and is also a learning remote.
  8. Mogli
    Mogli
    Feb 25, 2003
    764
    43
    +124
    I personally think the build quality on the 2011 is pretty impressive. Plus the Pio remote also has the learning function and huge code library :devil:
    Not to mention it being very good in stereo! :D
  9. Daneel
    Daneel
    Dec 5, 2002
    2,822
    68
    London
    +26
    I the same decision to make last Christmas, I also considered the Denon 3803.
    After a lot of reading I finally went for the Pioneer. I'm not sure what people are basing their opinions on build quality on. The 2011 is very well built and having seen the 555ES, I'd say the Pioneer puts it in the shade. It's not that the Sony was bad, far from it in fact, just that the 2011 is build like a tank and looks gorgeous.
