Vsx-d2011 - Usb
Discussion in 'AV Receivers & Amplifiers' started by Kuni D, Jul 8, 2003.
  1. Kuni D
    Kuni D
    Sep 30, 2002
    229
    +3
    Ello all :)
    Can any of the VSX-D2011 owners out there give some details on the USB functionality? Do you have to use some sorta software, or does it steal the feed of winamp for example - bit baffled!
    Definitely leaning towards it with a DV656A.
  2. jhjerpe
    jhjerpe
    Mar 1, 2003
    690
    2
    28
    North London
    +59
    I just plugged my 2011 via USB into a Mac (OSX) and it worked straight away, just apperead as another output on the sound control panel. I belive it is the same for Windows XP.
  3. Daneel
    Daneel
    Dec 5, 2002
    2,822
    68
    London
    +26
    Plug it in before you turn on the PC and it will auto configure and set it as the default sound card. It works very well.
  4. phenom2003
    phenom2003
    The usb connection only allows stereo though doesn't it?
  5. meep
    meep
    Apr 22, 2002
    587
    Ireland
    +46
    Yes
