vsx d2011 or Denon 3803
Discussion in 'AV Receivers & Amplifiers' started by dion, May 15, 2003.
Tags:
  1. dion
    dion
    What is the cheapest I can get these? And which is the best? I will eventually be using the amp with a set of M&S THX 500 speakers.
  2. jhjerpe
    jhjerpe
    Mar 1, 2003
    700
    2
    28
    North London
    +58
    I've got the 2011, but the 3803 is very good as well... not much in it really. Features both have some uniques, the auto set-up and MACC equalisation on the 2011 is really good.
    The best thing to do is go for a demo and decide yourself. You can get them very cheap online, but I am a big fan of the local dealers with demo facilities, you might pay a bit more but at least you can make an informed decision.
  3. dion
    dion
    Thanks for the advice but it can be dificult to find a dealer with both in stock in the Hampshire area so I can compare them back to back.
  4. damtom1
    damtom1
    I,ve just gone from a 3802 to a 3803,and i think the improvment is massive.It definately processes a lot clearer and crisper than the 3802,especially with films.Music is also improved,but not as much as the film soundtracks.
    It feels like i,ve got a new set of speakers!
